Coil replacement
Coil replacement
I recently bought a MSD coil and a new cap and rotor and need further instructions on installation of the coil. Are there rivets that need to be drilled out? Any suggestions for those without a drill handy? Thanks
-Rich305tbi
92' RS 305 tbi
dynomax headers, no cat, borla cat-back, open element, 160 degree thermo
free lock-up tc mod
-Rich305tbi
92' RS 305 tbi
free lock-up tc mod
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
To be honest with ya, I don't remember having to drill anything out. I think mine just had two small bolts holding it on, but if you don't have a drill, try using a dremil(spelling?). That is if you have one! Sorry if I wasn't much help.
'91 Z-28 5.7, SLP 1 3/4 headers, 4 inch Mufflex/Flowmaster cat back, gutted cats, Edelbrock intake, 8.5mm Jacob wires, MSD Blaster coil, S&W subframe setup, Jacob Pro Street Ignition, complete Kenwood system.
Car: 1992 Camaro Z28
Engine: 406
Axle/Gears: 4.10 GM 7.5 10-bolt
There is a bracket that attaches your coil to the intake manifold. To remove this bracket, you must drill out the rivets that attach the bracket to the coil. The rivets are aluminum, so they are pretty easy to drill with the correct size bit. I ground the heads of the rivets off with a bench grinder. That worked pretty well. Whatever you do, don't just set the coil on the manifold like I did for a while. The vibration killed it in only a few days, giving me all kinds of intermittent problems. Attach the new coil with the supplied machine screws to the bracket. Then mount the bracket to the engine as originally attached. Good luck.
1992 Camaro Z28; Engine:383 w/Ported Edelbrock RPM heads. Lunati Solid Roller Cam 224/232 .502/.502, Fluidampr, Comp Cams 1.5 Roller rockers and lifters, Comp Cams Triple Valvesprings, SVO 30 lb injectors. Holley/Walbro 255 lph in-tank pump, Haltech E6GM DFI, SLP 1 3/4" headers, 4" Mufflex, T56, SLP Clutch, Pro-5.0 Shifter, 4.10 Gear, Auburn Offroad Pro Posi. Super Ram. 17" X 9.5" Ronal FireHawk Rims w/ 275 40ZR17 Bridgestone RE 730's up front and Nitto Drag NT 555R's out back.
Double-Pump This! EFI Rules!
92camaroJoe
Aug 13, 2015 06:07 AM
