Speeodometer Problem (drops Off)
Old Jul 9, 2002 | 05:16 PM
FORMULA355TPI's Avatar
Car: 88 FORMULA / 88 IROC
Engine: 355 / 355
Transmission: T5 / TH400
Axle/Gears: 10 Bolt-3.73 / 9"-3.90
The car is an 88 formula tuned port with 5 speed.
The problem is that the speedo will flutter and sometimes drop off completely.
This is an intermittent problem you will be driving at 40 and it will flutter below and sometimes go straight to 0mph. It is giving the computer a bad signal as well because when it is real bad it kicks the car into limp mode..
I have replaced the speed sensor and the v.s.s, buffer already and the symptom is the same..
Any help would be greatly appreciated and could be profitable as well..
thanks,
JOSH
JS PERFORMANCE
Old Jul 10, 2002 | 11:50 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
The next place I would start looking at is the wiring itself. Sometimes wires do break within the insulation. I'd use a multimeter to test from point A to B on a VSS wire while moving it to see what happens. If I didn't find a problem there, I'd just start cussing as I usually do at my car :sillylol:
Old Jul 11, 2002 | 02:48 PM
Engine: 355 / 355
lAREADY HAD THE SPEED SENSOR WIRES TAPPED INTO A VANTAGE LAB SCOPE AND THE PROBLEM IS SO INTERMITTENT THAT IT WAS INPOSSIBLE TO CAPTURE IT ON THE SCREEN.
Ghettobird52
Jul 5, 2024 11:18 PM
Grant2k
Jul 10, 2018 04:01 PM
db057
Sep 4, 2015 07:57 AM
someone972
Aug 30, 2015 12:52 AM
92camaroJoe
Aug 13, 2015 06:07 AM
