140 AMP alternator & 16 volt battery
Old Apr 5, 2001 | 11:38 PM
Phil87IROC's Avatar
Car: 1987 IROC Z28
Engine: 6.0L LQ9 crate engine
Transmission: Performa Built 700R4
Axle/Gears: 3.42 10 bolt, Eaton/Moser
Can we just swap in a 140 amp B4C alternator into our cars without any other mods? Also, same question for a 16 volt battery??
Anyone done these mods lately?
Thanks!
Phil87IROC
Blue '87 IROC, 383 Crate Motor, KB pistons, AFR 190 heads, ZZ-9 cam, Edelbrock RPM intake, Hooker SC/LT headers, Edelbrock 750 cfm Carb (#1411), stock T-5, GM 3.42 rear w/Auburn posi.
Ohio Valley Dragstrip Trophy Bracket WINNER - 8.39 ET on a 1.82 sec. - 60'. Best MPH = 84.44. Still Tuning Carb!
Red '89 IROC L98, 700R4, T-Tops, K&Ns w/open air boxes, 160 T-stat, Hyper Chip, gutted MAF, 53kv coil, MSD wires.
Old Apr 6, 2001 | 03:26 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
You need a special bracket from GM to install the B4C alternator. Do a search for B4C, or 140 amp alternator - there were a few posts on this board regarding the bracket part number.
Tim
Old Apr 6, 2001 | 03:33 PM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Transmission: 700-R4
I wouldn't go using a 16V battery. I'm not knowledgeable in general about the finer details of electronics, but my mechanic when I asked him about 2 batteries said not to run them in parallel or I'd fry the whole car. That's 24V not 16, but isn't 16 the "redline" for the battery guage anyway?
Old Apr 6, 2001 | 04:19 PM
Stuart Moss's Avatar
To charge a 16 volt battery, you'll need the alternator to provide 18 or more volts. This means that you'd need a special alaternator, or the existing alternator with a special regulator to run a 16 volt, vice 12 volt electrical system.
That means that you'll have 18 or more volts with the 16-volt alternator running. I'd suspect the ECM, if it survives, wouldn't last very long. Ditto for every other electrical device in the car (the life of the headlights would be reduced).
You can't just put in a 16 volt battery in a 12 volt electrical system and expect it to work.
It is possible, but would require a lot of modifying (read expensive).
Old Apr 7, 2001 | 03:09 AM
rhawki's Avatar
<font face="Verdana, Arial" size="2">Originally posted by I ROCK:
I wouldn't go using a 16V battery. I'm not knowledgeable in general about the finer details of electronics, but my mechanic when I asked him about 2 batteries said not to run them in parallel or I'd fry the whole car. That's 24V not 16, but isn't 16 the "redline" for the battery guage anyway?</font>
If you run them in parallel you double the amperage, not the voltage. To get 24 volts you would have to wire them in series.
Just curious, why were you gonna run 2?
-Rich
Hotrodboba400
Dec 10, 2019 07:07 PM
sahlomonic
Sep 20, 2015 07:15 PM
gta892000
Sep 16, 2015 12:37 AM
1Aauto
Sponsored Vendors
Sep 8, 2015 11:14 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
