Any tips for disconnecting the starter ground wire?
Car: 89 IROC-Z
Engine: LB9
Transmission: 700-R4
I have the flywheel shield and starter bolts off, can't seem to reach the ground connection to the starter with a wrench and can't seem to wriggle the starter itself down between the flywheel and fuel lines either. Any tips? My dad's advice: Chevy's are a pita...
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
There are no ground connection wires going to the starter - just the positive battery (large) wire, along with 3 or 4 fusible links on the large lug, and the start (small) wire on the S terminal. You should be able to get a 1/4" drive ratchet & socket in there to remove the two nuts on the two electrical terminals.
Tim
Tim
eightsixseven
Dec 16, 2024 01:50 PM
db057
Aug 11, 2015 10:11 PM
