What the hell??
Old Apr 2, 2001 | 01:28 AM
86Tra/maro's Avatar
From: Newark,NJ The state where racing on I 78 rules.
What the hell??
I have a problem dealing with my head lights. If u look at my post I took a 86 Trans am that was wrecked in the front & Swapped a 87Iroc nose on it. My problem is when I turn on the low beam head lights, the high beam bulbs come on very dim!! When I turn on the high beams everything works just fine. Dont forget Ta's have 2 headlights & Irocs have 4 headlights. I'm stumped
njdaewoo
86 Tramaro 90% Trans Am/ 10% IROC/Z (nose, hood,& fenders)
Trans Am Mods as of 1/10/01
3inch
T.E.S/Flowmaster setup,gutted cat,gutted maf,relocated mat,373 gears,upgraded factory chip,255 liter h/press. walpro f/pump & throttle body coolant bypass
njdaewoo@excite.com
Old Apr 4, 2001 | 12:56 AM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
Are all 4 light assemblies grounded to the frame? Tan = low beam; lt green = high beam; black = ground.
Tim
Old Apr 5, 2001 | 12:13 AM
86Tra/maro's Avatar
If u mean each light having a seperate ground, no! The right & left side share a common ground on each side.
Old Apr 10, 2001 | 11:31 AM
83CAMAROMAN's Avatar
Car: 1983 Camaro Sport Coupe
Engine: 1986 305 C.I.D. Bored .030 over
Transmission: TH350 W/Shift Kit
Axle/Gears: 3:08
i had the same problem on my 83 camaro and the graounds had come losse on the lights, i reatatched em and have had no probs since
1983 CHEVROLET CAMARO with a 1986
305 C.I.D.V8 BORED .030 OVER
HIGH VOLUME OIL PUMP
FLAT-TOP PISTONS
MILD CAM
3" CAT BACK EXHAUST W/ FLOWMASTER MUFFFLER
KEYSTONE CLASSIC WHEELS.
B&M RATCHET SHIFTER
STAGE THREE SHIFT KIT
(she'll spin em into third)
"Wise man once say, friends dont let friends drive Fords!!"
FormulasOnly
Jul 23, 2018 08:47 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
92camaro350cci
Oct 14, 2015 09:29 AM
aaron7
Sep 30, 2015 09:15 AM
dimented24x7
Sep 6, 2015 03:51 PM
