Wiring sizes...question about the labeling system?!
Old Jul 12, 2002 | 03:07 PM
JMatlock88's Avatar
Car: 1991 Formula
Engine: 355 DFI Superram w/ R-Trim
Transmission: Probuilt 700r4
Can someone please enlighten me about how wiring sizes are organized. I used "1 awg" welding wire for my battery cable. It seems to not be enough, so I ordered the biggest cable summit had. It reads 1/0 awg on it. Which is bigger or are these the same? It is hard to tell visually... Thanks for your help.
Old Jul 12, 2002 | 03:21 PM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
Are both wires braided? Also, how did you determine that the first wire was not adequate?
Old Jul 12, 2002 | 03:26 PM
JMatlock88's Avatar
Car: 1991 Formula
Yes, they're both braided, "floppy" wires. I have approx 27 feet span of this stuff, that's why it's probably not working so hot. How did I determine...well, about 5 seconds worth of cranking 3 times in a row will drain the battery. My mini starter came with a length/guage table. It says to use zero guage cable when using 25-30ft length. I was unable to find something this big so I ended up with this 1/0.
Old Jul 12, 2002 | 03:32 PM
mudaholic's Avatar
1/0 is actually zero gauge.. as in, one zero.. 4/0 is 0000 gauge... etc.. im not sure why the battery gauge would make a difference in draining your battery though...
Old Jul 12, 2002 | 03:37 PM
JMatlock88's Avatar
Car: 1991 Formula
Thanks that is exaclty what I was lookin' for!
eightsixseven
Dec 16, 2024 01:50 PM
midge54
Dec 27, 2019 04:14 PM
Street Lethal
Apr 30, 2019 12:14 PM
Caspar
Jun 19, 2016 11:19 PM
Rakim_RS25TH
Aug 18, 2015 09:32 PM
