fog lites
Old Apr 10, 2001 | 05:51 PM
4SPEED's Avatar
fog lites
IROC fog lites go out when switching to hi beams. Has anyone modified it so the fog lites stay on when hi beams are on...if so what
Old Apr 11, 2001 | 07:39 AM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
Someone else is gonna have to clarify this, but yes, there is a way to fix it so the fog lites will stay on. There's a relay for that, that has a light green wire on it that has to be grounded in order for that to work. There was a post here recently about this same thing - that's how I found out. I'm going to do it also, but wrote down the info on how to do it, but it's at home...
KAM
I just went and did a search for it. The post is titled "anyone know how to do this" by "blade". Last post was on the 4th, so you could go back on this forum to the 4th and read it, or find it under the search option.
[This message has been edited by thunderstick (edited April 11, 2001).]
Old Apr 13, 2001 | 02:53 AM
PhantomTPI's Avatar
Car: 1986 Pontiac Trans Am
Engine: 5.0 TPI
i did a search for this, because i woudl like to do this to my 86 trans am...but i cannot find it...
1986 WS6-Equipped 5.0 TPI Trans Am
Random Tech High-Flow Cat
Two Chamber Flowmaster Muffler
Megs Custom 4.5" Stainless Steel Tips
1999 Grand Am GT In-Dash CD Player w/Equalizer(fits like '86 original)
5% Tint On Rear, 35% On Sides
OTHER RIDE:
1998 C5 6Spd. Corvette
Silver w/Gray Leather Int.
12/14 Options
Stock(for now)
Best 1/4th: 13.5 @ 104.4MPH
Old Apr 13, 2001 | 07:19 PM
Vader's Avatar
In case you were wondering about TAs:
Later,
Vader
"What a Day..."
Adobe Acrobat Reader
Old Apr 13, 2001 | 07:26 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
Here's the link to that topic....it was MARCH 5th...not April!
https://www.thirdgen.org/messgboard/...ML/000924.html
Apparently you just take the light green wire on the relay (see Vaders post) and ground it directly! Make sure you tape up the other part of the green wire or you'll trip the circuit all the time!!
If you have a 90 or up model, the relay is located under the dash and not on the firewall!!
Old Apr 14, 2001 | 01:04 AM
PhantomTPI's Avatar
Engine: 5.0 TPI
Thanks Vader for posting that...and also to 86TPI for the info.
http://www.pitt.edu/~zyhst/trans86/
OTHER RIDE:
12/14 Options
Stock(for now)
1992Z28!
Nov 19, 2015 07:33 AM
Eric-86sc
Exterior Parts for Sale
Nov 16, 2015 10:20 AM
sbrandon
Sep 9, 2015 07:31 AM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
