Mass Airflow Sensor problem?
Old Jul 14, 2002 | 10:38 PM
87bird
Guest
Posts: n/a
I just put an Accel Supercoil, and the Accel ignition module in and now my car won't start. It started having trouble starting when i put the module in and then i got the Supercoil and it won't start at all now. When I could get it to start, it runs fine except for when you press the gas a little much. Someone told me to check the airflow sensor. It's not the supercoil and module causing this, right???
-JOrdan
Old Jul 16, 2002 | 07:45 AM
lugnut's Avatar
Car: 1970 chevelle
Engine: Lq4 408
Transmission: th400
Axle/Gears: 3:73
Did you put all of the stock stuff back on a try it again.You only changed the coil and module,that shouldnt have a effect on it,but try putting your old coil and module back on and see what that does.Also if it does get to running,to see if your MAF is bad,take the end on a screwdriver and tap the side of the MAF,if the car stumbles or shakes, it is bad.
eightsixseven
Dec 16, 2024 01:50 PM
chazman
Aug 28, 2018 03:25 PM
Caspar
Jun 19, 2016 11:19 PM
stalkier
Dec 6, 2015 11:25 PM
chazman
Aug 22, 2015 02:01 PM
