AC fan switch let the smoke out! Help!
Old Jul 15, 2002 | 01:27 PM
RS'er's Avatar
the **** that adjusts how fast your fan blows AC when fizzle this morning when I started up my car. blue electrical smoke and smell came up from right above the ****.
What can I do? Is there a switch that needs replacing?
I'm going to the junk yard tomorrow anyway,how hard is it to swap in a new AC head unit? Or is there some cheap and easy fix to this?
Old Jul 17, 2002 | 12:06 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
The switch is removable from the control head & is replacable by itself. I'd get a new one.
Old Aug 5, 2002 | 01:38 PM
RS'er's Avatar
ttt,
How do you remove it?
Old Aug 6, 2002 | 12:17 AM
Jade Grey's Avatar
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
Basically you take off the radio trimplate.
Then pull the radio out a little. I can set mine on the passenger seat.
Remove the screws that hold the control panel.
Lower the control panel slightly. (It's held by the pull-wires for the fan ducting.)
Loosen and remove the clip that holds the wiring to the blower switch. Use of needle-nose pliers may help.
Pull out the selector **** from the switch. Be careful not to lose the spring clip that locks the **** in place.
Next remove the switch from the control panel. On my Firebird, there were two 1/4" screws.
Place new switch in the wiring clip. Attach switch to control panel. You could do it the other way, but I found it easier that way.
Then just put everything back together in reverse of disassembly.
The blower switch costs about $8 at the parts store by the way.
tglennon11
Sep 23, 2015 05:30 PM
64goatman
Sep 9, 2015 01:09 PM
85Special
Sep 3, 2015 04:21 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
