Need relay wiring help ASAP!
Old Apr 16, 2001 | 04:10 PM
Biochem's Avatar
Car: 2002 SOM z28
So I have two relays (20 amp I think) for the fans... and NO directions for either!
They both have numbers written on the sides:
30 for the 12V in I am pretty sure
and that goes to a 87, which must be the power to the fan. Then it has a 85 (with a diode?) and 86... one must be ground and the other for the switched 12V.
One is better marked then the other (2 different brands). Actually the one that came with the temp sensor has wires from the harness, but it isn't clear which is for the ground and which is to the switched 12V source (black and grey wires). I assume black is for ground and grey w/white stripe is to the sensor/switched 12V... or is it the other way around? I don't want to use the sensor because it doesn't fit any of my ports in my manifold!
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
Old Apr 17, 2001 | 09:44 PM
tpsierra's Avatar
This link tells you more than you want to know about relays. Down the page a bit the "Bosch" relay is dexcribed, using your 85, 86, 30, 87 terminology.
http://www.eatel.net/~amptech/elecdisc/relays.htm
Old Apr 18, 2001 | 01:49 PM
tpsierra's Avatar
Screw that last post, this one is much more concise!
http://www.the12volt.com/relays/relays.asp
Glowsock
Jul 24, 2025 03:15 PM
RazorN8
Jan 7, 2022 11:44 AM
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
Bert87
Aug 23, 2015 03:50 PM
