Easy question (I think)
Old Apr 19, 2001 | 01:15 AM
Bill D 91 RS's Avatar
How many wires to the O2 sensor? I'm looking at installing my led air fuel guage and I'm not real sure where the sensor is. I think I found it but it only has one wire on it. It is on the driver side of the card and I can get to it from the top side. Is that the right thing?
Sorry if not very clear
Bill
Old Apr 19, 2001 | 09:52 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
Yep.. One tan wire. You need to get the ground for the meter somewhere else as close to the sensor (motor/heads) The further away you get with the ground the less accurate the guage is.
Old Apr 19, 2001 | 10:10 AM
Thanks JoelOl75. Is there anything wrong with using a quick connect to tap into the sensor wire?
Bill
Old Apr 20, 2001 | 09:10 AM
JoelOl75's Avatar
I wouldn't because the signal in this wire is very small and cutting into the wire with a quicky will let the elements in. Solder it and tape well (or better heat shrink it)
I've had so many nightamares with those suitcase gizmos losing contact and causing gremlins that i quit using them for everything and in a pinch use a butt connector instead, shoving 2 wires in one side and one in the other.
MustangBeater20
Oct 29, 2022 09:20 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
BurlyChev
Aug 16, 2015 09:08 PM
