MSD mounting spots????
Old Apr 11, 2001 | 12:37 AM
88blkiroc's Avatar
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
I got my MSD-6A box and i have no idea where to put it. I still have my AC on the car too. Where can i mount this box? Anyone got a pic of how you have yours mounted? Thanks.
Old Apr 11, 2001 | 01:34 PM
Jza's Avatar
Jza
Check that thread in the Appearance forum. There's several pics and descriptions in there to give you an idea.
Mine's down behind the charcoal canister, btw.
Old Apr 16, 2001 | 12:05 PM
B84305-Streetmachine's Avatar
dont put it under the hood or outside the car. that would risk way too much ****. i stuck mine in the glovebox of my mopar..but since a camaro doesnt have a glovebox what i would do is put it underneath the dash next to the computer but i would put it far enough away so that u wouldnt have interference..
AIM: grvkill
ICQ: 29298583
Old Apr 16, 2001 | 07:34 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
Here's where I put a 6AL on my '92Z...
Tim
<IMG SRC = "http://albums.photopoint.com/j/View?u=1554272&a=11944559&p=46679642">
Old Apr 16, 2001 | 09:00 PM
88blkiroc's Avatar
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
I put it on the drivers side firewall and moved the relays to the fenderwell.
Old Apr 16, 2001 | 09:11 PM
RedRS91's Avatar
make sure to put it somewhere that will get plenty of air because it will get hot and you have to make sure it can cool, hope that helps
Old Apr 17, 2001 | 07:52 AM
scauffiel's Avatar
If this picture were at all visible you could see that I put mine on the battery tray. Of course you have to have your battery relocated to the rear for this to work but... I also put my PEDES valve over there as well.
Steve
Steve's Trans Am Temple
Old Apr 20, 2001 | 10:09 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
I made a bracket out of a thin sheet of aluminum and bolted it to the drivers side wheelwell next to the wiper fluid bottle. I think I even used a mounting tab on the bottle itself, and one existing hole in the wheelwell so I didn't have to drill anything. Gets plenty of air too.
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
86CamaroDan
Sep 29, 2015 10:08 PM
TheExaminer
Sep 6, 2015 11:40 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
