electronic spark control module
Old Apr 15, 2001 | 01:12 AM
442guy's Avatar
hey, i got a check engine light b/c my 50 tpi was running like dog doo, and i read the codes i got code 54 which is a open or ground in the esc circuit. every now and then it runs good for a minute then back to running rough and back firing under acceleration. this only happens at idle or off idle. i tried replacing the esc, but it ran worse. anyone have this problem befor? i really dont feal like taking the harness out and traceing all the wires.
Old Apr 19, 2001 | 09:45 PM
Ozzy88GTA's Avatar
Car: 1988 Trans Am GTA
Engine: 5.0 TPI
Transmission: TH700-R4
If you recently set the baseline timing, maybe the ESC by-pass is not connected all the way in and has worked itself loose. I know for sure that disconnecting the by-pass will give you a code 54.
I would check the connection and reset the code and see what happens.
Good luck,
Ozzy
Old Apr 22, 2001 | 01:58 AM
Lov2xlr8's Avatar
i would have to say that...........my ***** itch
Old Jun 7, 2009 | 07:09 PM
WickdEye's Avatar
Axle/Gears: M78 9 Bolt Borg Warner
Re: electronic spark control module
I have a 1988 Trans Am GTA 5.7 350 engine. I was driving bout 55mph down a city highway when the engine just shut off but I still had electral power cuz my stereo was still on, ligths, etc and everytime after that I tried starting it and engine just turns and doesnt kick over.. This is what ive done to try to solve problem, replaced with a new distributer cap, coil and rotor and still not starting! I also found under the passerger side dash which is a little yellow module and says on module is this"GM AC Spark Plug" should I replace this too?? Is this the Ekectronic Spark Control Module also?? Im planning on replacing the Ignition Control Module too which is located below the distributer! Thanxz for ur help
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
TrevinE
Sep 14, 2015 03:20 PM
Jlanz55
Sep 9, 2015 09:09 AM
Jlanz55
Sep 6, 2015 03:05 PM
Jlanz55
Sep 6, 2015 02:35 PM
