Derale Adjustable Relay Q's within...
Subscribe
Apr 25, 2001 | 04:29 PM
"Derale makes an adjustable relay (Part No. 16759). Available through Jegs (800) 345-4545 for about $42.
Features:
Adjustable turn-on from 140° to 260°.
Adjustable turn-off from 2° to 20° below turn-on temperature.
Can be turned on automatically when A/C is engaged.
Can be wired to augment factory switch, not replace it.
Can be manually turned on with a dash-mounted switch. LED indicator.
If running when ignition is turned off, the fan continues to run until turn-off temperature is reached. "
This is a quote from one of the tech articles on this site. I am removeing the ecm from my '87 IROC OE'd with dual electric fans. Can this part function with out the ecm helping it? I have all of the original wireing for the car that I can use if I need to but, for the sake of clutter, I want to remove as much of the old ecm harness as possible.
[This message has been edited by Remondi2 (edited April 25, 2001).]
Reply 0
Apr 25, 2001 | 07:13 PM
Quote:
<font face="Verdana, Arial" size="2">Originally posted by Remondi2:
I am removing the ecm from my '87 IROC OE'd with dual electric fans.</font>
First, I wrote the article. The products I outline in the article are designed to add electric fans to a car that's not originally equipped with such. This requires some modifications to the factory wiring.
In your case, you can use the Derale and/or Hayden to control one or both fans. Just follow the directions supplied with the kit.
Willie
Supercharged 1987 305 IROC-Z, Daily-Driver, Emissions-Legal.
Former Paxton (6-psig): 12.57 @ 111 mph.
Former Paxton (6-psig) & former 50-hp nitrous: 12.04 @ 114 mph.
Current ATI D1SC (Initially 10-psig): Projecting high 11's.
Future ATI D1SC (15-psig): Gotta catch them pesky 26-psig boosted TTA's!!
http://willie.camaro-firebird.org/
1987 "20th Anniversary Commemorative Edition" Z28 Convertible -- Super Chevy Show Class Winner, 1998.
Reply 0
Subscribe
