cooling fan help
Old Apr 29, 2001 | 08:30 PM
sweetgn's Avatar
cooling fan help
On a 92 Z with 350, where is the fan switch, and from reading other articles am I correct in thinking the cooling fan relay is on the driver's side firewall with a green/white ground wire for the coil ground of the relay?
As far as this people suggesting the brass switch 3 inches below the upper radiator hose, is there an existing plugged hole in the radiator for this or do you have to have it cut in. This is for a friend's car and I don't have it here to look at it.
Old Apr 30, 2001 | 07:15 AM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
The fan switch is located on the pass. side head, between #6 and #8 plugs. Relays should be on the drivers side firewall, by the brake master cylinder...
KAM
Old Apr 30, 2001 | 08:43 PM
sweetgn's Avatar
Thank you for confirming that.
Linson
Oct 24, 2025 02:00 PM
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
