ARG WHAT IS GOING ON!!!!!!!!
Old May 3, 2001 | 07:58 PM
matty350TPI's Avatar
Ok so I am overheating still. have replaced the relay, the coolant temp swith in the block, the cooling fan switch at the rear of the engine bay and have even tried another ecm after my local garage guy said that the ecm thougt the fan was always on even when it wasn't and that I should get a new ecm. Well I got one out of a wrecked firebird and changed the proms and it does the same thing as my original ecm. What gives I cannot understand this. The ecm thinks the fan is always on but the fan never comes on....HELP PLEASE HELP!
1988 IROC-Z T-Top "MATTSTOY"
350 Crate engine
370ft. lb Torque STOCK
5speed Centerforce clutch, Spohn Sub-frames, Jamex 1.5 Lowering springs, 2 1/2' Exhaust,ram air setup
Old May 3, 2001 | 08:39 PM
Vader's Avatar
(Replied on Tech/General Engine forum post)
Old May 7, 2001 | 03:00 PM
MAXGTA2002's Avatar
Is the fan motor bad?
Check to see if the black wire to the sending unit is grounded W/a test light.
Hope this will help.
3.1EyeCandy
Mar 12, 2004 10:43 AM
Stekman
Oct 27, 2003 04:08 PM
RBob
Apr 27, 2003 09:54 AM
Mike89GTA
Apr 29, 2002 11:58 AM
