Problem with manual fanswitch
Old May 10, 2001 | 08:47 AM
87 Trans Am TPI's Avatar
I am trying to hook my manual fan switch back up and I found the ground and auxillary, but I cannot find the constant, actually I believe I found it but there just isnt any voltage in the wire, and I have no clue why.I checked both the cooling fan and A/C fan plugs and the constant is showing no power on either. What could have happend since I last had it hooked up and where can I check? Thanks!
1987 Trans Am
5.0L TPI
Automatic, all pwr. op
Digital Dash
Flowmaster Muffler
gutted cat
removed MAF screens
TransGo Shift Kit
Old May 11, 2001 | 08:44 AM
Also, where does the constant that runs into the plug come from, I can hardly trace it more then a few inches. and when i said auxillary i meant accesory, thanks.
Old May 11, 2001 | 11:03 AM
JoeIROC's Avatar
try testing the +12 (constant) when the car is running. In my schematics, it is "hot in run". (NOT "hot at all times")
86 IROC TPI 305
700-R4 with Trans-go shift kit
K&N Air filters
Dyno-Max cat-back
Summit tranny cooler
CEI throttle enhancer chip
[This message has been edited by JoeIROC (edited May 11, 2001).]
jhawkeye
May 25, 2022 06:33 PM
formula1lle
Jan 29, 2016 10:56 AM
Juneb1022
Firebirds Wanted
Oct 12, 2015 08:12 PM
g.l.mos
Aug 22, 2015 12:02 AM
kyleb24
Aug 15, 2015 08:24 AM
