82 camaro, voltage light
Old May 9, 2001 | 12:18 AM
phantazy82's Avatar
since i don't have gauges in my car, i have to deal with the "idiot" lights. just today the voltage light started coming on when i hit my brakes. then it progressed into blinking on and off as i drove, now it is on constantly. no drain while my headlights are on and i don't have any trouble starting the car. also i checked my alternator connections and belt, all seem ok there. any ideas????????
1982 Camaro SC-Z
http://phantazystylin.homestead.com/camaro.html
Old May 9, 2001 | 08:57 PM
eightTfourTA's Avatar
Car: 84 T/A
Engine: 305HOL69
Have you checked the alternator's voltage output? Should be around 14.4VDC. If it's lower, this will trigger the light even though the car will still run, but it's probably running off the battery. A couple of times i've seen the light come on while the alternator still puts out a full charge, this can be a diode inside the alt gone bad.
DR Stevens
1984 Trans Am 305HO L69
sucks gas, hauls ***
1991 Firebird 305 LO3
for days when I need a/c
Old May 9, 2001 | 10:04 PM
stephenc's Avatar
Sounds like the alternator on the way out, or possibly a loose belt. Bring it to autozone and they can hook up the inductive tester and find out how much current your alternator is generating.
stephen - 89 GTA - https://www.thirdgen.org/rides/index...ew&rideid=1321
Old May 10, 2001 | 05:46 PM
phantazy82's Avatar
ya know, i had thought about that. i've had alternator probs in the past on different cars and when those were running off the battery the headlights dimmed and all that good stuff. i'm not thinking that, sounds more like the diode or such. i guess i'm gonna have to visit the 24hr autozone close to my house for a check. thanx.
1982 Camaro SC-Z
Old May 12, 2001 | 07:20 PM
phantazy82's Avatar
well, i found what is causing my voltage light to flicker and such. my electronic choke is acting up and the plug is broken.
1982 Camaro SC-Z
eightsixseven
Dec 16, 2024 01:50 PM
TheJoeY88
Dec 31, 2016 07:30 PM
Omega
Aug 10, 2015 12:46 PM
