Tach filter???????Help!!!!PLEASE
Old May 16, 2001 | 11:50 AM
idrag2's Avatar
Ok I got my MSD 6A today. Well I hooked it up and my tach falls on its face at 3,000 rpm under hard acceleration. Summit told me I need to find the tach filter on the car and bypass it. Can anyone tell me where the tach filter is. And whats the easiest way to get to it. Oh yeah what does it look like??? Can someone please help me????
Thank-you
I DRAG 2
Old May 17, 2001 | 09:53 AM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
My tach filter was located on the firewall just behind the distributer. The wire from the negative side of the coil that comes out of the distributer plugs into the filter, the filter is connented to the tach. Its about 1 1/2 inches long and cylinder shaped. Thats where mine was located, I have an 84 Camaro...yours is probably in a similar location.
best 1/4 mile so far: 13.4 @ 101mph
84 Camaro 305 ported & milled heads, 3 angle valve job, Edelbrock Performer RPM intake, Hedman full length headers, Accell ignition, Crane 274H cam, B&M 700R-4, 3000 stall speed, 4.10 gear,
M/T ET street tires
visit my website at http://www.geocities.com/jbenge/page1.html
Old May 17, 2001 | 03:52 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
Make sure that your tach is being driven by the tach output of the MSD box - it should no longer be connected to the coil or the output of the distributor module (2 pin connector).
Tim
FormulasOnly
Oct 2, 2015 05:52 PM
