key wont start car...pleez help
Old May 17, 2001 | 02:46 AM
Black Beauty's Avatar
Car: 90 Camaro RS
Engine: 305 TBI
ok...if i put the key to ON and jump the solenoid with a screwdriver it will run, but i cant start it with the key. Its NOT vats, i have it bypassed, and if it WERE vats it would not start from jumping the solenoid.
all my lights work and car runs but it wont start car! this all happened after installin my hooker Long Tubes (had to remove brake booster, which required workin under dash)( i could have moved/loosened a wire)
anyone know what it could be?
i also have a autopage alarm, does it have a starter kill?
i also have a loose connection on the solenoid iwth the wires, im wokrin on tightening it up, but the headers are in the way.
thx for all the help you may provide,
Rick
Rick
90 Camaro RS 305 TBI
400 small block, Hooker 1 3/4 LTs, Random Tech Cat, Hooker aero chamber cat back on the way!!
TH700-R4 with Trans-Go shift kit (corvette servo here...but not installed yet)
MacEwen Motorsports White Gauge Overlays
14" K&N X-Stream Open Element
GTS Headlight and Taillight covers
5% Limo Tint all around
Classic White Chevy Bowtie sticker on rear window
http://www.geocities.com/esvalenz
Man if my camaro were a rice-rocket all those mods would give me what...easily 50-60 hp!!!
"Just because I've done it, doesn't mean I knew what I was doing!" - Me
Old May 20, 2001 | 01:28 PM
87rustybluebird's Avatar
look for a purple wire (or yellow, cant remeber but it is thicker than the rest). try giving 12 volts to that wire and see if your starter kicks
Old May 20, 2001 | 08:15 PM
Car: 90 Camaro RS
Engine: 305 TBI
everyone is gonna ream me, but it was just a loose starter wire, the small one.
thanks anyways
Old May 21, 2001 | 07:18 AM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
We'll take it easy on you this time. Glad you found the problem...
KAM
eightsixseven
Dec 16, 2024 01:50 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Jae992
Aug 27, 2015 09:07 AM
Bryan F
Aug 18, 2015 02:28 PM
Winchester1094
Aug 18, 2015 10:23 AM
