MSD ingition
Old May 18, 2001 | 11:01 AM
MouseCamaro305's Avatar
MSD ingition
l'm having a hard time wiring my MSD ignition with 1990 IROC Z with a LB9 305 TPI- l got the 6 A ignition and blaster 3 coil off a 71 monte carlo with a 468 l need to know which wiring harness l need for my car dual connector (l think is what its called) or single without vaccuum advance. can l run the blaster 3 coil with a 150 shot of nitrous thats on my 305 or would that cause detonation?
thanks a lot guys
Old May 18, 2001 | 04:37 PM
idrag2's Avatar
Hey mouse, I just installed a 6A on my 89 formula, and have had nothing but trouble out of it. But anyway the harness part number for a dual connector is 8876 MSD #. If you have any problems with your box let me know and I will try to walk you through everything I did. I called MSD and they don't know S#@%. anyway.
Good Luck
I DRAG 2
Old May 18, 2001 | 10:53 PM
hey thanks a lot, l appreciate it, what kind of problems in general did you have with the box?
Old May 19, 2001 | 02:36 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Biggest problem I had with mine is a wild tach jump during full throttle. Yet to see it now that it's wired direct instead of the adapted kit they sell. Maybe I got lucky ?
-Welders get better penetration
Old May 21, 2001 | 10:22 PM
idrag2's Avatar
Besides the tach problem, with my ESC "Electronic Spark Control" sencor hooked up my car would miss and everything else at 3500 but if you unhook the ESC it runs fine. I called MSD and they have NO CLUE whats going on. They think it may be in myingiton module so they are sending me one FREE! So if they want to send me free parts I'm not going to bitch. I'll let you know how things work out...e-mail me if you have any questions. idrag2@yahoo.com
Later
i drag 2
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
sreZ28
Oct 22, 2015 08:21 AM
meeklay812
Oct 1, 2015 03:46 PM
86CamaroDan
Sep 29, 2015 10:08 PM
