any way to make my tranny lock into 4th??
i have a 91 z and would like a bit more top end speed, and my tranny ( 700r4) wont lock into 4th at high speed, ( obviously) , any way to do something about this????
<font face="Verdana, Arial" size="2">Originally posted by Stang Eater:
i have a 91 z and would like a bit more top end speed, and my tranny ( 700r4) wont lock into 4th at high speed, ( obviously) , any way to do something about this????</font>
I have experienced the same thing you are having problems with and you can not change it,yes b&m makes what they call a kickdown kit but it is the same thing the 700r4 has in it factory.All camaro,firebird and corvettes all will down shift at 3/4 throttle and no one has been able to change it,that part made by b&m was for other 700r4's such as monte carlo,etc that down shifts at 1/2 pedal or so.Call summit tech line at 330-630-0240 and they will tell you if you figure out how to get the 700r4 to go full throttle we can go 160mph all day long,and who ever figures out how to do it will be a rich man.I almost bought the part before the summit tech explained it and I also called sevaral gm dealers.If someone says you can and tells you how to do it be cautious.
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
GM make a kit that allows the tranny to shift at WOT. the part# is 8673948 and it was fitted to the corvette.
Hope that helps.
Rob
1987 IROC-Z Auto (LB9)
Black/grey interior with the stance of a streetfighter
I like to think of her as Arnold Schwartzeneger in a dinner suit
Mods
Custom exhaust. 4 Inch pipe from the headders all the way back to a single muffler at the rear. No Cat. K&Ns, AFPR and Air foil.
Future mods:
Cam change
New torque converter
New heads (maybe corvette L98)
Strut brace
Sub frame connectors
Ram Air
Current G-Tech times
0-60mph 6.26 seconds
1/4 14.74@100.2mph
Hope that helps.
Rob
Mods
Future mods:
Cam change
Strut brace
Ram Air
1/4 14.74@100.2mph
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
