The best place to mount MSD box?
Old May 14, 2001 | 12:20 PM
idrag2's Avatar
Well the topic says it all?
Old May 14, 2001 | 03:16 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
<IMG SRC = "http://albums.photopoint.com/j/View?u=1554272&a=11944559&p=46679642">
Tim
Old May 15, 2001 | 09:48 PM
idrag2's Avatar
I was told to mount the box in a cool "DRY" place like inside the car. I was also told that these boxes are prone to heat and water. So what should I do? If I mount it inside the car........WHERE?
I DRAG 2
Old May 16, 2001 | 04:40 PM
Biochem's Avatar
Car: 2002 SOM z28
Mine is under my charcol canister... check the archives for 1000 posts about this same topic.
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
Old May 17, 2001 | 03:36 PM
The PC board in the box is conformally coated, so I would not think that a mild moisture environment would cause a problem. This unit in the picture above has been in use for four years, without any problems, and the engine is washed down regularly with a garden hose.
Tim
Old May 21, 2001 | 11:37 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
i put mine in the gap between the winshield washer resevoir and the a/c compressor (passenger wheel well facing at an angle)
1989 Firebird
2.8 v6, t5 swapped in
Ram Hi-po clutch, Cold Air, 1.6 rockers,Lakewood LCA's, Lakewood Lift bars, Wonder Bar, 3" y-pipe, Random Tech Cat, 3" I-pipe, Flowmasters, MSd 6a, MSD Coil (Fireball in future) Accel 8.8 wires, MSD Ignition Module, Auto Meter Gauges (Water, Clock (needed one) Fuel Pressure, and 5" monster tach) 4th Gen Seats
" I'd rather run last in a full out race, than to NOT run at all ".
Terrell351
Jun 13, 2021 01:13 PM
Street Lethal
Apr 30, 2019 12:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
overdriv
Aug 20, 2015 03:52 PM
midias
Aug 15, 2015 05:07 PM
