tpi fuel pump doesnt come on when ign is turned on, nor when engine is cranking.
Old May 22, 2001 | 06:55 PM
442guy's Avatar
got code 54, its a 85tpi. the pump doesnt come on anymore, used to just come on when engine is cranking after a while, but not anymore. oil pressure switch is good,
the ign wire is good to the computer, pump is good, relay is good, also the green with a white stripe wire from ecm to relay is good,(tells relay to switch) cant get the pump to turn on through the aldl, if i give 12 volts to the relay it comes on. the only cut in the wiring harness, is where th ecm fuse is. there is a orange wire and a black wire coming from the ecm fuse holder, the black then gets spliced into an orange and straight to battery +. any suggestions? how is the ecm fuse supposed to be wired out? hard to troubleshoot the 85, everyone has schematics for 86 and up. dave
Old May 23, 2001 | 06:58 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
Here are a set of '85 wiring diagrams on line:
http://www.geocities.com/vtcamaro/Wire-Diagrams.html
Tim
RazorN8
Jan 7, 2022 11:44 AM
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
djmarch
Aug 9, 2015 05:27 PM
Kaweh
Aug 9, 2015 02:54 PM
