Cooling fan problem
Old May 11, 2001 | 10:59 AM
JoeIROC's Avatar
Cooling fan problem
The coooling (radiator) fan turns on when the coolant temp rises. However, the fan does not turn on when I turn on the A/C. Obviously, the fan relay works, but now what do I check?
I have a single fan setup, on a 1986 305 TPI.
Any help as to what the cause might be would be appreciated!
Joe
86 IROC TPI 305
700-R4 with Trans-go shift kit
K&N Air filters
Dyno-Max cat-back
Summit tranny cooler
CEI throttle enhancer chip
Old May 25, 2001 | 11:51 PM
Ryan_Alswede's Avatar
Car: 1992 Camaro RS & 1992 Camaro RS
Engine: 3.1 L v6 & 305 (5.0L) v8
Transmission: 4L60 Auto
check the A/C fan relay, YES THERE are two relays, it's off to the side of the other 2 relays, it's black and cylinder shapped, also check the pressure switch on the A/C system. Check for codes in the ECM, yes codes can be set even when no check engine like comes on.
krisner89
Oct 10, 2015 06:03 AM
Papaginos
Sep 27, 2015 03:29 PM
Ducati900ss
Sep 2, 2015 09:05 AM
JHX
Aug 29, 2015 02:30 PM
Leggman1
Aug 6, 2015 04:15 AM
