I just dropped a 350 in and I turn the key and it just clicks?
Old May 28, 2001 | 04:59 PM
JucinGTA's Avatar
I still have the 305 COMPUTER in it, but when I hit the key, it just clicks and then evrything blows out, but about 5 minutes later my alarm starts goin off and then everything works again, the alarm goes off cause it has power I know that. If I unplug coil it will turn over fine!!!! what the hell is goin on?
Old May 28, 2001 | 06:21 PM
JucinGTA's Avatar
I charged the battery, for an hour!!!! now with or without the coil on, you turn the key you here one click and then everything goes out!!!!!
Old May 28, 2001 | 06:23 PM
RyanSS's Avatar
Maybe a wire going to the coil is grounded out somewhere, check all your wires and make sure they are in good shape. when you say everything blows you mean it acts like it has no battery right? if so that means that either one of the battery cables is loose, or something is grounded. normally i would say that it is your starter, but since it cranks with the coil disconnected, then i wouldn't think that could be it.
89 RS (supposed 350) TBI auto
Old May 28, 2001 | 07:06 PM
JucinGTA's Avatar
Ryan you are the man!!!! it was the battery cable, that was loose!!!!! thanks alot!!!!!!
Jake_92RS
Jan 28, 2020 10:37 PM
Jae992
Aug 27, 2015 09:07 AM
TheExaminer
Aug 19, 2015 10:07 PM
tnrednneck
Aug 13, 2015 08:57 AM
Kaweh
Aug 9, 2015 02:54 PM
