ignition switch wiring
Old May 30, 2001 | 10:53 AM
JWS's Avatar
JWS
On my 89 IROC there is a relay located underneath a panel near the hood-release handle that has 4 wires. 1 small dark green wire (pretty sure it goes to the ecm), 1 green with white stripe wire that goes to the P/N safety switch, and 2 yellow wires. My question is, where do those 2 yellow wires go? It looks to me like they come from the ignition switch, but I would like to make sure first. The wiring diagrams in the haynes manual I have are almost completely useless and do not even show this relay. The reason I am asking is that when my engine gets hot and I let the car sit for a few minutes, then turn the key to start, nothing happens. The 2 yellow wires going into the relay are only putting out around 9 volts when this problem happens.
Thanks,
Joe
89 IROC 5.7L TPI
Old May 30, 2001 | 05:43 PM
Omar's Avatar
You are correct, those two yellow wires are coming from your ignition switch. When you turn your key to the start position, a full 12 volts should be applied to those 2 yellow wires. With only 9 volts, you have probably narrowed down your problem to your ignition switch, or the wiring from the ignition switch to that starter enable relay.
1989 IROC-Z 5.7L
NOS 150HP kit
ProBuilt 700R4, PI Vigilante 2800 stall lockup
Baer Brakes 12" Sport System
BRoss99
Aug 10, 2025 05:08 PM
89GTAOz
May 16, 2020 09:31 AM
Caspar
Jun 19, 2016 11:19 PM
Bryan F
Aug 18, 2015 02:28 PM
djmarch
Aug 9, 2015 05:27 PM
