Fan Wiring Questions
Old May 25, 2001 | 07:56 PM
RED91Z's Avatar
Hello I have a 91 Z with a 305 TPI it has the dual cooling fans and the problem is that the fans don't work at all and there is wire from the battery that was burned in two. So I put jumper in the spot where the wire was burned and when I started the car the passenger side fan was spinning and the wire burned up. So I thought the wire was to small so I put another bigger in the same spot it did the same thing and the wire fried. So I was wondering what would the problem be and how can I wire the fans so they both come on with using a toggle switch. Is there anyway to do this???? Thanks
Old May 31, 2001 | 09:33 PM
farbyrd's Avatar
Dude don't do it. Your fans are telling you that they quit and don't want to work for you no mo, and if you force them too with a toggle switch they're gonna torch the place.
Believe them. Go to a S-yard or unfriendly parts store and get a new one if you got the ducks. I went with a 84 Honda dual fan on a toggle in my 84 byrd, but some are more picky. Good Wrenchin.
Old Jun 2, 2001 | 10:43 AM
bottledpower's Avatar
Car: 85 IROC
Transmission: 700 r4
the reason you are frying wires is because the drivers side fan is smoked. they must be wired in paralell or the pass. side wouldnt work at all. if you can isolate the fans you could use the pass. side fan temporaraly until a replacement was found.
85 IROC 350 11:1keith blacks,.555lift erson roller cam,1.6 crane roller rockers,edelbrock intake,holley 4150 750dbl pumper, nitrous oxide,full length heddman headers,true dual exhaust, 11"stall converter, 700R4, 3.73 locker, certified engine and electrical systems mechanic
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
Ikes 91Z
Dec 9, 2015 03:49 PM
redmaroz
Aug 16, 2015 11:40 PM
Leggman1
Aug 6, 2015 04:15 AM
