brake lights no workie
Old Jun 3, 2001 | 04:00 PM
89ROC's Avatar
The problem is that the 20A fuse keeps blowing. Every time I put a new one in, it immediately blows. I know there is a short to ground somewhere. Instead of tracing the short, I just want to run a new wire back to the brake lights. There is one orange wire coming from the fuse block that goes up into the dash then back to the brake lights (I assume). Does anyone know where this wire is routed, so I can bypass it?
TIA!
89' Iroc-Z
ZZ3 short block-355 TPI ZZ9 cam
NOS 150 shot.
blah...blah...blah..
95' T-56, 6-speed
99' Z' rearend w/ 4.10's
1997 black Trans AM
LT1, A4, basically stock.
13.87 on the G-tech
Old Jun 3, 2001 | 04:49 PM
Stuart Moss's Avatar
I don't know physically where your orange wire is routed, but I can tell you what my 1991 GM service manual says it connects to.
From the 20 ampere fuse, it goes:
1. To the brake pedal switch.
2. To the hazard flasher (in the convenience center).
3. To the power input for the convenience center electronics.
Note that the brake pedal switch (#1) has two contacts (at least for my 91) that switches power, one wire (a light blue) goes to both rear brakes and the other contact is to switch power (via a yellow wire) to the 3rd brake light.
Replacing the wire from the switched side of the brake switch may not solve the problem of the stop/hazard fuse blowing since it also powers the convenience center electronics and hazard flasher.
Checking those two components (#2 and #3)would be as easy as simply unplugging them. Then the fuse will only be powering the two brake lights and center brake light, in addition to the wiring up to where you disconnected it to the convenience center.
Running another length of wire to the rear may be more work than locating the short.
Good luck whatever you decide.
//Stuart
Old Jun 3, 2001 | 06:32 PM
89ROC's Avatar
Where is the conveinence center located? Maybe I'm just not sure what the service manual means by "convenience center".
Thx.
Old Jun 3, 2001 | 07:07 PM
On my 1991 Camaro, and this is ONLY from memory, it is between the steering column and the center hub, up under the dash in the midst of all the wiring. I think it is toward the firewall, black and about 5 x 7 inches.
Look for a cylindrical can, which will be the emergency flasher. It plugs into the convenience center.
I was going to say turn on the emergency flashers and let your ears follow you to the clicking of the flasher until I remembered what your problem was!
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
stalkier
Aug 21, 2015 01:54 AM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
