HI=OFF
Old Jun 3, 2001 | 11:16 AM
camaro6spd's Avatar
HI=OFF
when I turn on my fan it works in all modes except high, I have been told that a connector is at fault b/c it melted, he says all th GM cars he wrorked on had this problem, can you verify it?? And he says it is under the hood where the wiring goes through the firewall, where can i find this?
Old Jun 3, 2001 | 11:47 AM
RARE-ROC-Z's Avatar
hey mine is like that on my S10, just thought i would note that..
Jarrad
1990 IROC-Z L98 350 TPI
TH-700R4
G92- 9 Bolt Borg-Warner 3.27gears
Bright Red Hardtop/ Grey "Custom" Interior
NOT STOCK, NO WHERE CLOSE!
NEW RED PAINT and WELD PROSTARS.
DAILY DRIVER: 1991 GREY S10 2.5L/5SPD -FOR SALE. leaving for army.
Old Jun 3, 2001 | 04:06 PM
camaro6spd's Avatar
ok, so it just might be a GM problem and not the jacka$$ who put a system in my car and ****ed with the wiring....
Old Jun 3, 2001 | 11:14 PM
RARE-ROC-Z's Avatar
no i think it might be the jack *** . because mine didnt do it till after i pulled the assembly to change the lights behind the dash, so i know i did it, but i dont care about that vehicle so it doesnt matter!
Jarrad
TH-700R4
Old Jun 4, 2001 | 01:38 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
Check the high speed blower relay near the fan, under the hood.
Tim
Old Jun 5, 2001 | 07:09 AM
camaro6spd's Avatar
would that have a little blue fuse next to it?? On the drivers side??
Old Jun 5, 2001 | 09:41 AM
AaronIROCZ's Avatar
Moderator/TGO Supporter
no it would be over by the fan motor. also check to see if the relay is even getting the high load power. not the wire that does the switching but the wire powering the fan. Should be a larger wire going to the relay. My 89 camaro did the same thing and i traced the wire back to a sh-ty connection. i reworked the connection and it worked fine ever since.
89 Iroc 350 TPI,
Forged pistions
Comp roller Cam .510 lift 230dur
Flowmaster exhaust
Dart Iron Eagle heads 200cc runners 64cc chambers
MINI RAM SOON!!!!!
stock TPI for now 24# inj
