no spark
Old Jun 3, 2001 | 06:25 PM
nate88iroc's Avatar
no spark
My car is not getting any spark from the coil or plugs. I have changed the distributer, ign module, pick up coil, msd 6AL, coil, cap and rotor, ESC module, and I'm getting over 10 volts on the pink and white wires going to the ign module. Any help will be apprecated.
nate
Old Jun 7, 2001 | 11:39 AM
Ryan_Alswede's Avatar
Car: 1992 Camaro RS & 1992 Camaro RS
Engine: 3.1 L v6 & 305 (5.0L) v8
Transmission: 4L60 Auto
check the coil to see if it is good, yes I know it's new but you have to rule it out, the other thing it could be is that the ECM is not grounding the Coil so you would never see a spark when you crank over the motor, depending on the year of your Camaro. This isn't a custom setup with the MSD box, This MSD coil is just the one that replaces the stock one right???? Oh one more thing check the motor's ground strap.
RedLeader289
May 28, 2019 01:47 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
