Gauge lights no workie workie :(
Old Aug 3, 2002 | 10:31 PM
Nasty_Bird_'90's Avatar
The gauge lights in my bird decided to quit on me. The "dummy" lights still work and so do the gauges themselves. I read a thread last week about the dimmer switch. I don't think thats the problem b/c if it were, wouldn't they work sometimes and not others? I did check the connections where the plug meets the dimmer switch and all is well there. The fuse is not blown. This is starting to annoy me....alot ! I'd appreciate any help you guys could give. Thanx.
Old Aug 3, 2002 | 10:37 PM
by the way, the dome light works fine. I can turn the dimmer switch up and it will turn on. This is another reason i think the switch isn't the problem.
Old Aug 3, 2002 | 11:21 PM
2vmodular's Avatar
https://www.thirdgen.org/techbb2/sho...hreadid=119396
Old Aug 4, 2002 | 04:24 PM
Thanx man, but that was the thread i was referring to in my original post. Nothing there was of any help. I tried all the ideas there and no help. Thats why i posted this one. Like i said, everything else works fine and the fuses (gauges and inst lmps) haven't blown. Any other things it could be? Thanx again
Old Aug 4, 2002 | 06:15 PM
2vmodular's Avatar
wiring schematics for the dash light circuit are avaliable at:
http://www.geocities.com/modularmoto...gen/dashlights
remember that current flows in a loop. not only do you need power going into to the dashlights, you also need a good ground. a break anywhere in the loop will stop electricity from flowing.
Old Aug 4, 2002 | 10:21 PM
Eternal's Avatar
gauge pod wiring
does anybody have a schematic for the acual gauge pod? the new wiring harness used "idiot" lights, and I want to use my full gauges. I have the old plugs from the dash, I just need to know what wire are what so I cant run them.....
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
firebirdta84
Interior Parts Wanted
Aug 30, 2015 09:28 PM
justin57
Aug 20, 2015 07:05 PM
Omega
Aug 10, 2015 12:46 PM
