my temp gauge STILL wont work.
Old Jun 11, 2001 | 06:49 PM
birdofprey83's Avatar
Car: 1989 Firebird
Engine: 2.8
My darn temp gauge will not move!!
I have replaced the sender, the gauge, the wire connector.
I have done the test were you put a 100 ohm resister between the temp wire and ground and the niddle moves.
I need to get this fixed i almost blew my new engine :|
its a 2.8 F.I.
Thanks,
Chuck
I'm not shy, I just
observing my prey.
My Firebird site
Old Jun 12, 2001 | 11:06 AM
Camaro_hunter_d's Avatar
<font face="Verdana, Arial" size="2">Originally posted by birdofprey83:
its a 2.8 F.I.
Thanks,
</font>
ok you replaced the sender and the connector...You splice in a indenpendant source and it works...you might have got a bad sender...maybe the wrong one even. I used to work in parts retail it happened all the time.
Old Jun 12, 2001 | 11:42 AM
BlackZee's Avatar
Make sure you get the correct sender for the year of the temp gage, they are different for most years.
Old Jun 13, 2001 | 05:46 PM
Andrew H's Avatar
is it possible there's a break in your wiring ? -I doubt it but worth a try -but sounds like you've already tried running a separate bit of wire from end to end...
Bubbajones_ya
Jul 6, 2024 08:32 PM
codeysabatini
Nov 10, 2015 04:07 PM
codeysabatini
Sep 20, 2015 11:36 AM
corey8084
Sep 17, 2015 02:56 PM
86IROC112
Sep 11, 2015 04:04 PM
