Install Power Windows
Old Aug 6, 2002 | 05:31 PM
LUPS's Avatar
HELLO GUYS,
I have a 92' z-28 and did not come with power windows or power door locks i have two doors with the power windows and power door ocks that i got from the local wreck yard. my question is do i need to do anything else besides mounting all the stuff to my og doors, by the way i don't know where to connect the wires from the motor of the window or the power door locks. ? can you guys help me with any info on how this might be achievable.
thank you
Lups
:hail:
Old Aug 6, 2002 | 07:37 PM
Eternal's Avatar
it would probly make it easier if you went back and grabbed some of the wiring for the windows and such out of that car. you arent going to get all of it because it runs way up under the dash, hidden behind a sheild. but you should get the switch connectors and switches since these motors are two wire instead of the conventional 3 wire. the only other things you should need are the caps that go where the window cranks used to be. and depending on if your going to wire it the origional way, you may want a fuse block and such...
Old Aug 7, 2002 | 12:28 PM
LUPS's Avatar
yeah i went back and got most of all of the wiring & stuff but i have no idea how to wire someo of it. ? what i have done already is mounted the motors and replaced all of the wire. but i don't know where the wire goes when it has come out from inside the door.. and the relay and swithes are all done. i just need to rewire the motors and switches. but im kinda lost on doing that. any more info would be apreciated..
Old Aug 7, 2002 | 10:49 PM
2vmodular's Avatar
hope your 92' z28 isn't a daily driver, having windows that don't open is not good during the warm summer months.
wiring diagrams and other relevant info are avaliable at:
http://www.p71interceptor.com/thirdgen/powerwindows
Old Aug 7, 2002 | 10:50 PM
2vmodular's Avatar
http://www.p71interceptor.com/thirdgen/powerlocks
Old Aug 8, 2002 | 02:53 PM
Eternal's Avatar
as far as where the wires run, the switch wires run back with the tail lamp wires and crosses over to the console under the seat. the wires for the pass side run way up into the dash where you dont want to try and get to.... so I suggest find a good spot to run the wire where nothing will rub on them.
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
stalkier
Aug 13, 2015 12:59 PM
