84 ECM plug location
Old Jun 17, 2001 | 08:02 AM
night-rider's Avatar
does anybody know where the ecm plug is at on the 84 berlanetta's? I have looked every where and I can't find the stupid thing...the only thing I have found that is close is a big plug that is beside the master cilinder...any help would be great..thanks,mike
84 berlanetta...smokes when u start her up...no speedo,or tach...no blinkers or head lights...but she will burn the hell out of the tires! :-)
Old Jun 19, 2001 | 09:45 PM
meridius's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7 TPI (Now HSR)
Transmission: 700R4 by Probuilt
Axle/Gears: 3:27 9 Bolt Posi W/ Discs
ive seen some computers located by the steering column and most are under the dash by the right kick panel
Old Jun 20, 2001 | 03:24 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
The ECM, and its associated two connection plugs, are located on the passenger side, under the dash, behind the kick panel - above where your feet would be, if you were sitting in the passenger seat. The ALDL connector is located to the right of the steering column, under the dash.
Tim
LittleFranks
Sep 17, 2015 12:22 PM
Jae992
Aug 27, 2015 09:07 AM
g.l.mos
Aug 22, 2015 12:02 AM
djmarch
Aug 19, 2015 12:07 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
