Sensor or gauge??
Old Jun 16, 2001 | 02:41 PM
dilligaf's Avatar
Sensor or gauge??
OK, Before I rip apart my dash I figured I'd ask. When I start the car the oil pressure reads 30psi. Usually , but not always at some point during my ride the gauge tops out (goes past the 60). Sometimes it even comes back to 30 but usually not.
Should I start by changing the sensor?
D
Old Jun 16, 2001 | 04:08 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
Yep - change the sending unit...
KAM
Old Jun 18, 2001 | 10:12 AM
MAXGTA2002's Avatar
Hes right but keep in mind some cars have two sending units. just a thought.
Old Jun 18, 2001 | 03:55 PM
dilligaf's Avatar
TWO???? Where's the second one?
Old Jun 23, 2001 | 09:08 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
well..theres one that feeds the gauge, and theres another sending unit that feeds the computer so the fuel pump will shut off if the oil psi drops too low
1989 Firebird
2.8 v6, t5 swapped in
Ram Hi-po clutch, Cold Air, 1.6 rockers,Lakewood LCA's, Lakewood Lift bars, Wonder Bar, 3" y-pipe, Random Tech Cat, 3" I-pipe, Flowmasters, MSd 6a, MSD Coil, Accel 8.8 wires, Auto Meter Gauges (Water, Clock, Fuel Pressure, and 5" Sport Comp Tach)TB Bypass, 4th Gen Seats
Coming for my v6:
Panhard Bar, 4thgen front seats, Nitrous, Line Lock, Posi, Spohn Torque Arm & Subframe connnectors
"I'd rather run last in a full out race, than to NOT have run at all"
Old Jun 24, 2001 | 03:07 AM
Jza's Avatar
Jza
That's not a sender, that's a pressure switch.
Bubbajones_ya
Jul 6, 2024 08:32 PM
TrevinE
Sep 14, 2015 03:20 PM
86IROC112
Sep 11, 2015 04:04 PM
FormulasOnly
Sep 10, 2015 09:07 PM
