timing timing timing!!!
Old Jun 21, 2001 | 12:42 AM
colincamaro's Avatar
My 89 305 tbi will not time right. When I disconnect the tan bypass wire and set it to 6-8 deg. BTDC it runs pretty smooth , but when I hook the wire back up it backfires and barely runs. Do you think the distributer is worn out. fuel system seems to be working well.. anybody seen this before?
Old Jun 21, 2001 | 12:51 PM
Camaro_hunter_d's Avatar
well are you reconnecting it while it is running?.. I know it sounds stupid but people have done it.
Old Jun 23, 2001 | 12:24 AM
I did shut it off before reconnecting,I wonder if its an ESC problem . still looking into it
Old Jun 23, 2001 | 05:59 PM
RBMZ28's Avatar
Car: 87 IROC (low 12's)
Engine: 400 sbc .040 over
Transmission: 700r mod
have the same problem any replies????
87 IROC WITH 409(.060OVER400) MINIRAM,NOS(125HP)TRICK FLOW PORTED HEADS,C.C.CAM,FLOWTEK HEADERS,CUSTOM PROM,MODIFIED 700R TRANS,2400 B&M CONVERTER,3.73POSI REAREND.
LOOKING FOR THE 11 SEC. ZONE.
Old Jun 24, 2001 | 12:10 AM
is it possible that a bad knock sensor is telling the ESC to retard the timing so far that the engine hardly runs?
Old Jun 24, 2001 | 06:38 PM
found the problem. It was a bad pick up coil.
bamaboy0323
Sep 3, 2015 06:07 AM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
