FUEL PUMP BLUES
Old Jun 22, 2001 | 05:07 PM
Fast86TA's Avatar
FUEL PUMP BLUES
ok, I need a new fuel pump, I want to put on an electric external, I don't have a whole lot of horses so I don't need something HUGE so I looked at Holley's Standard Pressure pump, BUT it says not recomended for fuel injection..... so my problem is that I need an electric external pump for a fuel injected car with not a whole lot of mods, but a few... nothing major
Old Jun 22, 2001 | 06:28 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
Why not just pull the tank & replace the original pump with a Buick Grand National / Cyclone pump, which has a bit higher flow capacity over the stock pump (41 vs. 24 - 28 gph @ 50 psig)?? It's not that big a job to do the pump, once the exhaust is dropped.
Tim
Old Jun 23, 2001 | 04:38 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
NextGen Parts (www.nextgenparts.com) has just what you need! Accel high-pressure EFI fuel pump, 45 psi rating, suitable for use up to 500hp for $139 and includes the mounting bracket! This pump is great even if you're not using alot of HP right now... and if you decide to modify in the future you can still use this pump all the way up to 500HP!! This is the pump that I'll be using when my intank craps out on me just like the last TWO have!! Don't listen to people who say it's "simple" to drop the tank and put in the new pump! If they say it's simple then they've probably done it a dozen times or more! My entire exhaust system on my car is welded and I don't think CUTTING it down and then paying someone to weld it back up is quite worth it! Install the in-line pump in your car in about an hour, leave the dead intank pump inside the tank and the inline will pull through JUST FINE!! Oh yeah, make sure you add a relay when you hook up the pump.... if you don't, the pump will draw too much amperage and eventually die!!
1986 Trans AM
305 TPI
Well over 200,000+ miles (speedo/odometer non-funtional! Odometer reads 142,000)
4 Wheel Discs
9 bolt Borg Warner Rear (2.77's....oh joy) :P
Completely Stock
Current Project: upgrade to a 355 TPI, 6" rods, 9.5:1 Compression, Stock TPI ported, 24#/hr LTI injectors, Hedman Shorty Headers, SBC Stock Casting heads pocket ported, Comp Cams XE262-14 TPI Cam, Ed Wright Fast Chip, Holley AFPR, TPIS airfoil, MSD wires, MSD 6-AL Box, Hypertech hot coil!!
Old Jun 24, 2001 | 03:15 AM
Jza's Avatar
Jza
It's welded at the cat too? That sucks for you. A fuel pump is "simple" just time consuming and involved. It was actually a very relaxing job for me.
Old Jun 24, 2001 | 04:30 PM
<font face="Verdana, Arial" size="2">Originally posted by Jza:
It's welded at the cat too? That sucks for you. A fuel pump is "simple" just time consuming and involved. It was actually a very relaxing job for me. </font>
What Cat?? LOL! Got rid of that restrictive POS a long time ago! I guess for SOME people the exhaust isn't an issue... it is for me though!
Old Jun 29, 2001 | 01:07 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
If you go to an external pump, you still need to drop the tank and remove the intank pump and replace the pickup from a carbed car.
I just installed a Holley external pump on my 86 Trans Am but since I had a carb, I didn't have to do anything to my tank. I just had to put high pressure lines from the tank to the fuel pump, then to the fuel filter and finally to the hard lines on the chassis.
I am nearly finished with my TPI conversion.
High Speed Run: 157mph
Best 1/4 mile run: 14.94@91.67mph
WS6 Trans Am.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
