Quick question about harness and problems
Old Aug 10, 2002 | 10:44 PM
Ions91Z28's Avatar
Car: 1991 Camaro Z28
If I had a 1992 TBI RS Camaro and wanted to switch to a TPI System. Assuming I bought a 86-88 systems, how would I go about switching everything to working.
I'm assuming vats would be a problem, and possibly the cold start injector. Is there a way to get around these without actually programming the prom? or would I need to do that as well.
Old Aug 16, 2002 | 07:15 PM
Ions91Z28's Avatar
Anyone? Did I word the question wrong?
Old Aug 17, 2002 | 12:19 AM
Jza's Avatar
Jza
VATS wouldn't be a problem assuming you use an 89 chip. Using an 89 chip would take care of both of those problems you state: the VATS, and the cold start injector.
If you installed an 86-88 TPI setup, then to add VATS you'd only need to add the one blue wire to your harness and run it to your existing VATS module (assuming you switched the 86-88 chip out for an 89 chip)..
Now since you specified "without actually programming the prom" I'm talking about only switching out the chip for an 89 chip. You can accomplish the same thing through programming which I'd suggest.
Once you have it installed and the 89 chip in, you'd only need to disconnect the cold-start injector connector. I went a step further and removed the wiring altogether (it's a surprisingly segregated circuit. Only one wire to cut.)
Old Aug 17, 2002 | 12:59 PM
Ions91Z28's Avatar
Thanks again.
Jorlain
Aug 24, 2022 05:11 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
