Please help exorcise the demons!!!
Old Jul 1, 2001 | 01:27 PM
MILT's Avatar
My buddy's ride is giving us the fits...
Yesterday had several no start fits--like a dead battery, after several times of trying the key, though, it would start right up.
Note: this has been happening off and on for several weeks. (loose starter ground?)
Last night, all lights dimmed as we were driving, gauges started bouncing around, and it seemed like the fuel pump of injectors or something were cutting out as the car would bog and would run over about 2500 rpm.
This morning, the only thing that works is the radio, as long as the key is back in the "acc" position. Otherwise nothing else works. Upon initial inspection, the plastic piece covering the "+" cable at the battery had a couple holes melted into it. Where the heck do I even start with this?!
Old Jul 1, 2001 | 04:43 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Try taking the POS batt cable off and see if its corroded or loose. From the way its acting, I would say you have a poor connection at the battery. Also, one rule of electronics is: Resistance=Heat. Based on the melting "POS" cap on the battery, I would say you have some resistance (i.e. poor connection).
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
New2Chevy
Oct 4, 2015 11:27 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
mirage2991
Carburetors
Sep 11, 2001 02:58 PM
sb406camaro86
Carburetors
Aug 9, 2001 02:02 PM
fulo
Aftermarket Product Review
Jun 27, 2001 09:16 PM
