87 LG4 Relay/Sensor I.D. on Firewall
Old Jul 1, 2001 | 10:45 AM
Changa2's Avatar
87 LG4 (Auto)- On the Drivers side of the firewall between the fender and power brake unit is a bracket holding 4 different relays.
Closest to the fender is the 'VAC' (I think), having 3 wires and a vacumm post.
Closest to the P/B is the 'ESC' (I think) having 5 wires and a rubber seal.
Hanging just in front of the 'ESC' is a 5 pin
relay. What is the proper name for that and what does it control?
Nearly identical to that one is a 4 wire relay that hangs between the 'ESC' and the 'VAC'. What is the proper name for that and what does it control?
I'm just trying to get a better understanding
of the wiring system and what relates to a non-cc Engine/Ignition and which systems are just taking up space.
Thanks for your help and time.
Old Jul 1, 2001 | 04:39 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
You are correct about the ESC and the "vac" sensor. that is about what they are.
As for the relays, the one with the fat ORN and TAN wires is for the fuel pump. Before you even ask, YES YOU DO HAVE AN ELECTRIC PUMP IN THE TANK. The other is for the cooling fan.
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
Old Jul 1, 2001 | 04:56 PM
Changa2's Avatar
Thanks GM. How did you know that was one of my nagging curiosities?
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
mfp189
Sep 27, 2015 09:25 AM
armybyrd
Sep 21, 2015 10:28 PM
gta892000
Sep 16, 2015 12:40 AM
sandman92084
Sep 12, 2015 10:27 PM
