swapping from an 82-84 85 gauge cluster to an 85+ 145 cluster...
Old Jul 1, 2001 | 05:38 PM
Demon Z28's Avatar
Car: 2001 Camaro SS
Engine: Almighty LS1
I was told by a friend doing something similar that the connectors in the back do different things ...
I've got an 83 Z28 currently with the split 85 .
I've got an 85+ (I think 87...) 145 cluster...
What is the difference between each cluster?
Do the Fuel, Oil, Water and Battery gauges still use the exact same wiring as the 82-84?
Or do I have to end up re-wiring this stupid thing so I can have a full set of gauges and know exactly how much fuel I've got, etc.
This is sort of an urgent thing as I'm putting my gauges in tonight.
Old Jul 1, 2001 | 05:55 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
As long as you're not upgrading from idiot lights to gauges I think you'll be ok.
Old Jul 1, 2001 | 06:10 PM
Demon Z28's Avatar
Car: 2001 Camaro SS
idiot lights?
sorta new on this whole gauge thing...
Old Jul 1, 2001 | 08:00 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Some cars came without the tachometer and only had warning lights for oil pressure and temperature. As long as both clusters have the tach then no worries.
If you're really worried about it, you can just swap the speedometer between the two clusters. You might also want to swap the odometer rolls between the speedos so that your mileage is still correct.
Old Jul 1, 2001 | 08:18 PM
BlackZee's Avatar
I recently swapped my 85mph speedo ('86) for a 145mph speedo ('87). Follow Apeiron's advice and only swap the speedo's, not the entire gage cluster, very easy to do. I also used the temp gage from the '87 because my '86 did not work, turns out I had to buy a new temp sensor (located in the head) for the '87 gage. The temp sensors are not the same for all years, I know that '85 & '86 are the same and it is different for '87. Also, be careful with the new speedo, tougher to keep it within the speed limit until you get used to it!
Old Jul 1, 2001 | 10:52 PM
Demon Z28's Avatar
Car: 2001 Camaro SS
Ok thanks for clearing that up for me... I feel like less of an idiot now
I have the ones with the tach
I've never seen the one with the lights on them... can someone post a picture of them??
Old Jul 2, 2001 | 01:52 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I don't have a picture of one, but there should be an illustration in your owner's manual, if you still have it. The tachometer was replaced by the fuel gauge, and the other gauge locations had warning lights behind them.
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
fonzie85
Aug 13, 2015 11:50 AM
ChevyZ71
Aug 13, 2015 07:30 AM
