Are all wiring harnesses the same 82-92???????
Old Jul 3, 2001 | 10:27 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
I have a 85 SportCoupe that i'm giving a full
body makeover to an 89 RS,and I was wondering about the wiring harnesses for all
camaro years.I pulled a Pulldownhatch from a
tottaled IROC,and when I tried to find the connectors to plug it in there wasn't any.
I have the connection for the Hatch release switch in my center concole,but I couldn't
find the connectors for the Pulldownhatch
wiring harness to attach to.
IF YOU CAN HELP IT WOULD HELP ME OUT ALOT.
Old Jul 3, 2001 | 10:57 PM
Glen's Avatar
Engine: chevy 383
Transmission: tci streetfighter auto
Axle/Gears: 3.70 moser 9"
Well, the short answer is no they are not the same. In February I just finished putting in an 88 350 setup in my 85 sport coupe and had to reroute at least a dozen wires and could not have done it without the factory shop manuals for both years. The books are pricey but worth their weight in gold as far as I'm concerned. Generally speaking the connectors are the same but the wires don't necessarily go to the same places. By the way welcome to Thirdgen.org I have been watching these message boards for quite a while and have learned a bunch. There is no substitute for good information however you get it. Good luck with your project.
Red '85 MPFI V-6 T-5 Sport Coupe (bought new),now an IROC in sheeps clothing.
Rebuilt and installed '88 IROC L-98 TPI,700-R4,3.27 posi/disk rear,instrumentation, steering gear, and all suspension parts (even the wonder bar)
Mods:
IROC wheels, Hi-perf. rebuild on 700-R4,TCI sizzler torque conv.,B&M megashifter, L-98 .030 over,balanced,decked,blueprinted, SR Torquers, KB pistons,9.1:1 CR, port matched stock TPI, comp cams .450/480 206/210 cam, all free mods, subframe connectors, Edelbrock TES/jet hot coated, CATCO cat, Hooker catback, MSD 6A, airfoil, AFPR, K&Ns, polygraphite bushings all around, 1989 IROC memcal in summer, ARAP memcal in winter.
Old Jul 3, 2001 | 11:18 PM
82 cross fire's Avatar
That is a good start but what you are doing is adding an option that was offten put on a the dealership and not the factory. Most of the add ons have a seprate harness that is routed after the fact. As for the assimbly manuals that is the best thing you can buy. It will save a lot of cussing in the long run. Good luck
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
stalkier
Dec 6, 2015 11:25 PM
g.l.mos
Aug 22, 2015 12:02 AM
stalkier
Aug 21, 2015 01:54 AM
