Noid light tester?
Old Jul 4, 2001 | 12:37 PM
Project 92 RS's Avatar
Car: 1992 RS
Engine: 5.0
Transmission: auto
Axle/Gears: 3.08
Noid light tester?
What are these? I've heard that they are for testing the injectors. If so, how do they work and are they worth buying? Thx.
92 RS 25 ann. ed. bone stock.
5.0/TBI/T-5
T-TOPS
Many mods to come.
Old Jul 4, 2001 | 04:33 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
They don't test injectors, they test injector circuits. Injectors need to be flow tested and the injector coils should be checked for coil draw.
The noid light is just a light that plugs into the injector plug and will flash when the injector should be firing. This lets you know the ECM has control over the injectors and that the wiring is OK.
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
skeltor
Feb 2, 2016 10:37 AM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
Ian Irvine
Sep 4, 2015 08:08 AM
luvofjah
Sep 3, 2015 07:08 PM
