Blower Motor or Heat/AC Switch??
Old Jul 6, 2001 | 03:33 PM
Stoopalini's Avatar
I was sitting at a stoplight with my A/C running and the blower fan set on high. All of a sudden the fan cut out.
Now it works on every setting except the high setting. I assume this means a resistor blew somewhere.
My question is, will a replacement dash switch fix this? Or is that just a switch that leads to the control module somewhere else?
As always, any help is greatly appreciated!
Thomas.
1992 RS Camaro - Red
305-TBI/5 Speed Manual- 3.08 geared rear
1.6 Roller Rockers / Adjustable Fuel Regulator with high flow pump / Open Air K&N Filter / TBI Spacer / ADS Super Chip & custom burned Off-Road Only chip / MSD ignition
Headers - 3" Cat'Back - Flow Master - dual chrome tips
Adjustable Coni shocks & struts & 16" factory wheels
Old Jul 6, 2001 | 06:02 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
Sounds like your blower high speed relay went out - the resistors only power the blower motor on the 3 lower speed settings. The relay is located under the hood, near the blower motor & is powered from a fusible link connected to the large lug on the starter motor.
Tim
1992 Z28, 305 TPI 5 speed, 12.1 sec @ 114.7 mph
1984 Berlinetta 305 TPI Auto, 13.8 sec @ 99.7 mph
Old Jul 6, 2001 | 08:17 PM
Stoopalini's Avatar
Ahhhh, that explains it! Thanks Tim.
My brother and I troubleshot this for about 1.5 hours. We determined that the relay for the high speed setting was good, but the constant power was cold. I put a jumper wire from the battery to the red wire on the relay, and it kicked right on.
We traced the red wire through the harness, but couldn't find where it went.
From what you said, I should be checking a fusable link (or fuse in my case: the links were replaced with fuse holders) down at the starter.
Thanks again,
Thomas.
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
355sbcTPI
Aug 19, 2015 04:38 PM
mhatfield 14
Aug 15, 2015 10:47 AM
Street Lethal
Aug 13, 2015 08:28 PM
