auto door lock makes car shut off!!!!!!!
Old Jun 29, 2001 | 03:43 PM
SpRaYd91Z28's Avatar
Okay, here's the scoop...I took a friend of mine home the other day, and when we got to her house she was trying to open the door, and I told her just push a lil harder, and it still would'nt open, so I hit unlock on my side of the car, and the car stopped running, it completly shut off....then I started it up again, and trying to hit unlock, and it died out again....I started it up again and had her crawl out dukes of hazzard style.... =/ What could this be? Any suggestions on where to start?
Zach
1991 Z28, Black ext. Grey leather interior.
-Engine/exahust Mods:
-=MSD 6A Ignition/MSD Blaster Coil
-=Flowmaster/no cat
-=Headers
-=Air foil.
-=Superchip.
-Drivetrain:
-=2k Stall
-=1LE Aluminum Driveshaft
-=Customer Shift Kit.
-Free Mods:
-=TB Coolant
-=Modified air box
-=Removed Smog Pump (shorter belt).
-==Best Motor E.T. 13.59@102==-
Old Jun 30, 2001 | 09:42 PM
Duffster's Avatar
Car: 2001 Camaro Z28/1995 Camaro Z28
Engine: just a little 5.7(LS1-320/340 RW)
Transmission: SMOOOOOOTH T-56/Auto. . .
Axle/Gears: 3.42 and 2.73
an extremely rare freak occurance? ? ?
I can only guess if you did this several times and it happened exactly when you pressed the buttons each time, you might have some wires crossed all of a sudden unless you've been working or having someone else work on your car recently...
noticed you said when you pressed the unlock...
do the manual switches no longer work?
Duffster (age 32)
BEAT DOWN HARD 88' Camaro Sport Coupe,
1978 Caprice Classic 305 motor havin'(WITH NO COMPUTER),Torker II intake, Edelbrock 1406,600cfm w/vacuum secondaries,Accel HEI Supercoil/Cap/Rotor Sparkin',84' POS 700R4 Tranny usin', 84' Z-28 Nose clip wearin',
84' Z-28 Hood covered,
AND THE TIRES:
245/60-16 Firehawk SS20 on Firbird rim(1-passenger rear),
235/55-15 BF Goodrich's on CompTA's on Z28 rims(2-on front),
235/60-16 Pirelli P600 w/a curb check or 3 also on Firebird rim(1-drivers rear),
REAR HATCH MASTER OF ALL!!!
DuffsterCamaro@HOME.COM
Owner of the Camaro 0 out of 10 Third-genners approve of, no longer part of the non-existent Iowa crew.
Old Jul 1, 2001 | 12:13 AM
They work, and it has to be a wire crossed, cuz the other day it stoped doing it, and then started again just as quick as it started....BLah!
Zach
Old Jul 11, 2001 | 09:01 AM
georgiaboy27's Avatar
Does the movie CHRISTINE ring a bell???..hehehe couldn't resist...
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Fronzizzle
Aug 9, 2015 01:15 PM
BrianI
Aug 9, 2015 11:52 AM
