What am I missing here????? Cooling fan related
Old Jul 13, 2001 | 11:13 PM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
Working on a fiends 89 formula. Trying to figure out why the cooling fans won't come on. At the relay's, you can run a jumper wire and turn them on that way. I am getting power out of the trigger wire and there is a good ground. The fans will run when you ground the computer, when you go to pull codes or adjust the TPS. I even grounded the wire to the Temp Sending unit and nothing, zilch, zero. Everything seems to be wired correctly. The Temp guage works fine, but I am missing something stupid aren't I. We switched out the relay's and still nothing. And it really can't be the relay's because when you ground the computer, they turn on. Any insight will be greatly appreciated. Thanxs!
-Jason
"Get this, no man with a good car needs to be justified."
91 Z28 305 TPI/5 Spd
92 Formula 305 TPI/5 Spd
[This message has been edited by Jaysz28 (edited July 13, 2001).]
64goatman
Sep 9, 2015 01:09 PM
Fronzizzle
Sep 8, 2015 12:10 PM
85Special
Sep 3, 2015 04:21 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
