trunk (hatchback) pull down motor
Old Aug 16, 2002 | 11:56 AM
Richardmichael's Avatar
The hatchback locking mechanism has stopped working, it unlocks ok but when you close the trunk it does not pull itself shut and lock. Should one of the two wires connected to the contact plate be live? How can I test the motor?
Old Aug 16, 2002 | 12:53 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
The red with white stripe wire that connects to the blue wire form the pull-down unit supplies the +12v source. Check the 15a fuse labeled "LID" in the fuse block. I will e-mail you scans of my HELMS manual to help diagnose it. I also sell the repair parts for the 86-91 hatch pull-down units if you need any. Good luck, Lon.
Old Aug 18, 2002 | 09:36 AM
SpeedJunkie's Avatar
Car: 88 IROC
Hey lonsal if you could please send me those pages too it would be much appreciated:hail:
Old Sep 16, 2012 | 11:14 AM
timz's Avatar
Car: 1988 5.7 tune port irocz
Engine: 5.7 tune port
Axle/Gears: 2.77
Re: trunk (hatchback) pull down motor
theres a white wire i dont know were it plugs into
Old Sep 16, 2012 | 11:46 AM
lonsal's Avatar
The white wire plugs into a black with orange stripe wire on 89-91 model years. For those cars there it is used as a switched ground to turn on and off the hatch light, there is no manual switch for the hatch light.
This Tech Article I wrote will help diagnose and repair your hatch pull-down unit.
https://www.thirdgen.org/tech/hatchpulldown.pdf
Lon
colton_carlson
Mar 8, 2019 12:21 PM
Mickeyruder
Sep 2, 2015 02:45 PM
AmorgetRS
Convertibles
Aug 31, 2015 11:55 AM
madsv1000
Aug 20, 2015 06:45 AM
86White_T/A305
Aug 17, 2015 12:16 AM
