HELP PLEASE!!!! NEW OWNER NEEDS HELP
Old Jul 16, 2001 | 10:23 PM
telstar's Avatar
Hey Gang,
Just purchased 1987 IROC Coupe 5-speed TPI.
Came with receipts for motor rebuild (10k ago) Within the last 5,000 miles car had a Performance chip installed along with new Distributor and wires (red color)
Problem is the car is running rough... Really sounds like a bad plug or wire but reading this board also makes me think the chip may be faulty. No smoke from exhaust but it smells REALLY rich and car runs very cold - Below 1/4 mark on temp guage.
I will pull and inspect all plugs and wires tomorrow.
Code Scanner turned up no error codes. Just code 12.
Any other info would be appreciated! I am new at this!!
Thanks,
Sean
87 TPI with G92 (3.45)
Old Jul 16, 2001 | 11:52 PM
Ryan_Alswede's Avatar
Car: 1992 Camaro RS & 1992 Camaro RS
Engine: 3.1 L v6 & 305 (5.0L) v8
Transmission: 4L60 Auto
reason for running cold is probley the guy has a 160* thermistat in there, check the timming and I would personally go back to a stock chip just for trouble shooting problems right now. You might also have a vacum leak.
Old Jul 17, 2001 | 12:04 AM
telstar's Avatar
thanks Ryan.
Old Jul 17, 2001 | 12:13 AM
telstar's Avatar
I may be way off track here....All smog equipment looks to be intact but there is no belt on the smog pump. Could this cause problems??
Old Jul 17, 2001 | 12:59 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
You may want to make sure the plug wires are going to the right cylinders too.
Lbibb
May 5, 2016 12:00 AM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
meeklay812
Oct 1, 2015 03:46 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
