Standard gague cluster replacable with a digital?
Old Jul 12, 2001 | 11:24 PM
Wolf986's Avatar
Heya guys, love this board.
Im buying an 86' Berlinetta this weekend, and I've seen pictures of some of the digital dashes that you guys have. Man do they look SWEET. What Im wondering is if there is any possible way to swap out the guages with all the digital doo-dads?
Thanks!!
Mike
Old Jul 17, 2001 | 09:05 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
You have to settle for the dash that's in there. I don't believe there is any aftermarket supplier selling replacements for the stock Berlinetta digital dash ! A *regular* camaro dash will not fit in there !
I am still hoping to see a berlinetta dash that reads over 85 MPH before I die !!!
John in RI
berlinetta@prodigy.net
Old Jul 17, 2001 | 11:35 PM
unknown_host's Avatar
Car: 1989 Iroc Z L98
i am stupid nevermind
this sucks for me now. are you sure that new gauges dont fit in berlinettas, like out of a z28?
[This message has been edited by unknown_host (edited July 17, 2001).]
Old Jul 18, 2001 | 10:17 AM
AaronIROCZ's Avatar
Moderator/TGO Supporter
Unless you replace the WHOLE dash carrier it will not interchange.
89 Iroc 350 TPI,
Forged pistions
Comp roller Cam .510 lift 230dur
Flowmaster exhaust
Dart Iron Eagle heads 200cc runners 64cc chambers
MINI RAM SOON!!!!!
stock TPI for now 24# inj
87 Trans Am GTA 350 TPI
had engine fire hope to get running soon
Flowmaster exhaust
Old Jul 18, 2001 | 01:45 PM
by the whole dash carier, do you mean just the pod with all the guages in it, or something else. please be specific, i am worried.
Old Jul 19, 2001 | 01:39 PM
John in RI's Avatar
I installed an 86-Z interior into an 85 Berlinetta about a year & a half ago and it was a pretty complicated swap.
I was lucky in that the donor car - (86 Z) was a 305ci LG4. That meant MOST of the body connector wiring (from fuse box to firewall connector) was pretty close to matching up. The Berlinetta was also an LG4 motor. (The wiper wiring had to be re-wired because the body connector leads did not match.)
As far as what you need in order to make a "regular" camaro gauge swap into a digital Berlinetta ---
Steering column
Floor console (complete)
dash housing (complete)
wiper motor
heater-A/C box (interior & motor compartment)
Speedometer cable
Speedometer sensor (on tranny)
The wiring harness that runs from the driver kick panels area to the rear lights is not the same must be rewired or replaced. (If it's replaced - then the rear light harness under the rear bumper needs to be replaced or re-wired as well.) Some heater AC re-wiring under the hood is also needed. If your Berlinetta has cruise control you *may* need to rewire that as well since the berlinetta has the cruise buttons on the steering wheel.
This swap can be done - That car I did the work to is still driving today...... but my advise to you is to have a complete z28 parts car & a lot of patients before starting the job !
John in RI
Berlinetta@prodigy.net
Jeremys87
Jul 14, 2022 09:08 PM
355sbcTPI
Aug 19, 2015 04:38 PM
tnrednneck
Aug 13, 2015 08:57 AM
ChevyZ71
Aug 13, 2015 07:30 AM
Sanjay
Aug 12, 2015 03:41 PM
